Reply To: Head Gasket shape
Traction Owner’s Club › Forums › Technical › Engine › Head Gasket shape › Reply To: Head Gasket shape
#38992
André
    The tear drop shape of the head gasket is to match the shape of the top of the cylinder head , which is tear shaped on the exhaust valve side. The cylinders in the block are round..  If a round hole gasket is fitted the tear drop side will not be fully held down by the head, it will disrupt the exhaust gases going out also it would eventually burn away. I’ve recently have an issue with a head gasket set. 1950 4 cylinder Prefro engine. I got a complete gasket set from Citroen Classics and discovered that the head gasket is for an H van ( round holes ) not a traction. Seem that the manufacturer/ supplier has packed the wrong gasket in the traction gasket sets.  Awaiting a replacement.  So If you’ve ordered or received a gasket set . Best to check it out
