Reply To: Fuel octain ratings and mirrors !
Traction Owner’s Club › Forums › Technical › Other › Fuel octain ratings and mirrors ! › Reply To: Fuel octain ratings and mirrors !
#21885
David Selfridge
    Hi Rod
    Yes the door handle brackets (you just fit standard 8mm motorcycle mirrors to the bracket) from a club Member, Mike Bigland Mobile 07812023896 £30 per pair, mike@paradeigma.plus.com, I have them on both my cars a fantastic invention. My mirrors (motorcycle mirrors 8mm diameter) were purchased from Demon Tweeks for about £14 per pair?
    I run both my cars on standard Fuel with SPITFIRE Fuel Catalyst inserted in the tank approx £40 or purchased at NEC 23/24/25  March 2018 £25 each. The small Spitfire is inserted into the tank.  diamond shaped approx 30mm long it will boost your Octane 95  >99/100 they come supplied in a plastic mesh pocket which I melted a lenth of stripper plastic through the mesh (small blow lamp) so enabling removal from tank. I have them fitted to both cars and have completed many, many miles without any problems.
    Spitfire Motering Products, +44(0) 1403 754173 http://www.spitfirefuelcatalyst.co.uk
    Davy Selfridge
