Reply To: WATER LEAK @ WATER PUMP
#21954
David Selfridge
    Chris & David
    Thanks For the helpful posts regarding my Legere’s leaking water pump, further investigation has proved that the diagnosis by Chris was spot on, and the recent noisy release  bearing. The water leak is coming from the shaft seal, the shaft only has a brass Grease cup with a screw lid rather than a Grease nipple, so unable to pump Grease into shaft seal. The leak may be cured if  I could pump the seal with Grease,  as the leak is quite small.
    Davy
