Chris & David
After My last post I went out to the garage and unscrewed the brass cup and screwed in a Grease nipple (they looked different thread) pumped a lot of Grease into seal, out came water and very old Grease then clean Grease (15 pumps) leak has now completely stopped.
The little brass oil cup to oil the release bearing has now been filled with motor oil and has considerable cut the noise from same.
Question
This little cup seems to keep takeing oil, can it be given to much oil? Or do you keep filling till oil seepage stops, frightened that oil may get onto Clutch.
Davy
