Reply To: Is this gear ok?
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Is this gear ok? › Reply To: Is this gear ok?
#22462
    Without a doubt. You need to take the upper shaft out and sort it out. Leaving it, it will grind for sure going from first to second and I would think it probable that the bushings have moved, blocking the oil holes. You sure don’t want a gearbox like in the latest FP. Don’t chance it, take care of it. Once you have second set right on the shaft, it will shift beautifully.
