Reply To: Hand Brake Cables
Traction Owner’s Club › Forums › Technical › Brakes › Hand Brake Cables › Reply To: Hand Brake Cables
#22665
    Chris – no magic involved – they should just pull out.  If I understand you correctly they must be seized due to the ravages of time and muck so a liberal dose of WD40 (other makes of releasing agents are available) ought to do the job.
    If possible leave to soak and maybe a few gentle taps with a blunt instrument will also help to free them off.
    If they do not respond to gentle persuasion you might try twisting them out with a pair of molegrips (other makes of locking pliers ….etc.).  However, if you are intending to re-fit them, take care not to crush the outer sheath onto the cable.
    Bernie.
