Reply To: Removal of 6v under-dash wiper motor
Traction Owner’s Club › Forums › Technical › Electrics › Removal of 6v under-dash wiper motor › Reply To: Removal of 6v under-dash wiper motor
#22731
Peter Fereday
    Ditto on the well done. A pig of a job but had to be done. My motor was seized because the grease inside had gone solid – like resin as you say. Will check on the rest of the mechanism now to see if the bushes are starting to seize also, as it still occasionally seems to lock and has to be persuaded to start with a wiggle under the dash…….
    Peter
