Reply To: Adjustable bottom ball joints
Traction Owner’s Club › Forums › Technical › Suspension & steering › Adjustable bottom ball joints › Reply To: Adjustable bottom ball joints
#22767
    Peter,
    It is imperative that you retain everything but the shims, (426201, 203 and 667), and the bottom cover plate (426198).  The ball assembly does not have to be disturbed.
    The adjuster merely eliminates the (awkward) process of shimming.  It should only be used with a good condition set of cups, spacer and ball because it is neither designed nor capable of taking up wear.
    The difficulty in assembly with this – as with the original shims – is that, with the vehicle supported on the jacking point of the lower arm,  when the bottom cover plate is released the hub unit tends to descend into the lower socket under its own weight.
    I therefore recommend holding the upper wishbone and the lower arm apart with a jack or similar before even removing the three screws holding the bottom cover plate and then keep them locked apart during reassembly to enable the components to be replaced without having to fight the weight of the hub whilst the parts are clamped up.
    Once the adjuster is firmly fixed in position with the three screws the central “adjusting” screw should be tightened fully to ensure the ball/cup/spacer assembly is correctly seated within the lower arm with the spacer ring securely clamped between the two cups so that the later cannot move and cause wear to the housing.
    Hope this helps – but ask if you want more detail.
    B…………….
