Reply To: Dim instrument lights on my 5411B
Traction Owner’s Club › Forums › Technical › Electrics › Dim instrument lights on my 5411B › Reply To: Dim instrument lights on my 5411B
#22907
Roger Grix
    Hi Larry,
    Unless your speedo glass is dirty, it has to be either a bad connection on the live or earth or a dodgy or 12V bulb.
    Check the bulb directly on the battery.  If it is OK, take wires, +ve and -ve, directly from the battery to the light socket and see what happens. If it’s OK, remove one at a time and see which is the bad connection/broken or damaged wire.
    If the bulb is OK but connecting wires directly from the battery does not give you a bright light, it could also be a poor connection between bulb and bulb holder or bulb holder and instrument case.
    Hope this helps.
    Roger
