Reply To: Oil pressure
#22934
    Hi Richard
    According to the manual the pressure should be 2 bar to 2.5 bar (~30 to 37 psi) at 1000 rpm at 60-65 degrees C. So yours is a bit low compared to spec.
    However – if it’s not making knocking noises I wouldn’t worry about it. Davy’s and Alistair’s experiences seem to bear that out. Keeping the oil topped up to the maximum mark will allow the pump to deliver its best pressure.
