Reply To: Front left door inside locking mechanism
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Front left door inside locking mechanism › Reply To: Front left door inside locking mechanism
#23158
Bertel Bjorvik
    Hi,
    I chopped off two of the tabs holding it together on the opposite the spring. Could not get anyone to tack weld it. Drilled a 3.2 mm in the “cover” used a 4 mm tap.Then used a 4mm counter sink machine screw to put the “lock” back together. A nylon lock nut on the bolt to lock the “cover” in place so the mechanism could move freely. Cut off the excess of the bolt. Works perfectly now.lock left front doorIMG_20180616_133056IMG_20180616_133107
