Reply To: Induction Coil
Traction Owner’s Club › Forums › Technical › Electrics › Induction Coil › Reply To: Induction Coil
#23229
David Selfridge
    This happen to my Traction a few years ago, I had to run an earth wire to the distributor, the car never misfired again.  I am sure you have already taken out the plugs, but if you have not it’s worth checking, as I have experienced a plug centre broken and floating around, given intermittent spark (new plug recently fitted) Check the Distributor Cap for cracks although unlikely as your car would always be misfiring. You should also check the filter from the tank outlet, located at the top of the fuel tank, inside boot it may be clogged and restricting the fuel supply.
    Davy
