Reply To: Big 6 oil leak
Traction Owner’s Club › Forums › Technical › Engine › Big 6 oil leak › Reply To: Big 6 oil leak
#23652
    STOOOOOOOOOOOOOOOP!
    I screwed up – the seal size I quote above was for the CRANKshaft  seal mod.
    The seal you require is actually a 30x40x8 R23 NBR shaft seal and the cap has to be modified for the 40mm OD.
    If you want further info please ask – may even be able to find some pictures.
    B………….
