Reply To: Big 6 oil leak
Traction Owner’s Club › Forums › Technical › Engine › Big 6 oil leak › Reply To: Big 6 oil leak
#23654
Non Member
    Thanks Berni for the info I thought that may not be a seal after looking on traction spares website, I’ve steamed  off the front of the engine so hopefully I can see where it’s coming from, according to the history with the car the head was off two years ago, so I was also thinking it may be from the head,if there is an oil way on the front,  there was a lot of oil thrown around the front so now it’s clean I will run it up and have a look, there was no leak when I first ran it  but after about twenty or so miles on its second trip it just appeared (running out of the bonnet vents) a little disconcerting! Like the sound of your mod I did think the first sizes sounded a bit on the big side for a cam , thanks once again. Martin
