Reply To: Not engaging gear
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Not engaging gear › Reply To: Not engaging gear
#23750
Richard Larter
    Hi Michael
    I find that running the engine until it is good and hot helps. The heat in the flywheel helps break the rusty bond between the clutch and flywheel. Then start the engine in gear with the clutch depressed, handbrake on and the wheels chocked and fingers crossed.
    Cheers Richard
