#23760
Alistair
    Like others, I have a two plastic, in-line, fuel filters, one before the carb. Not only can you see crud, you can see if fuel is arriving at the carb when priming with the fuel pump lever.
    The carb inlet valve may have stuck closed. Although it is usually the simple things that cause the problems rather than opening/replacing everything only to find a blocked hose or leak!
    Alistair
