Reply To: Boot hinge
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Boot hinge › Reply To: Boot hinge
#23932
Paul Barnard
    Hi Simon
    Here are my hinges – my car is a 1950 French built 11BL
    hinge pin3hinge pin2
    You can see that on my car they are a dome headed pin and the ends are just hammered over like a rivet. They are 60mm long and 7mm in diameter and as such they are identical to the door hinge pins.
    hinge pins
    Chris has these available from our vast selection of club spares
    hinge pins_003
    If yours have had bolts put in I would suggest that you go for the oversize pins.
    Cheers
    Paul
