Reply To: Sunshine roof seal
#24153
Jack Peppiatt
    Ahh, I can save you the trouble, armed with your info, I ventured out to the garage in the British rain and with a bit of diligent searching have found the two screws, which appear to be countersunk, raised head screws or set screws, about 45mm back from the front edge and were hidden just behind the opening edge trim, brown with corrosion, they had perfected the art of camouflage against the headlining light brown colour.
    With this additional knowledge of the inner workings I now discern that the closed cell neoprene strip which is stock to the moving portion of the sunroof, is simply a rectangular section, which has adhered to the under side of the roof at some point, in turn tearing the outer skin off. This has allowed the inner foam to become stuck to the roof, until percussive persuasion is administered.
    I will remove the strip and replace it with a similar item, since it probably has done some good, the head lining being unmarked to date.
    Thanks all for your help, problem solved
    Regards Jack
