Reply To: Sunshine roof seal
#24166
Jack Peppiatt
    Nick Olsen has sent me some photos of his sun roof. The first shows a side runner, which seems to have a cover of a rubber sort of material stuck on it, whereas mine just has the metal strip, worn shiny in places and in the past lubricated with something, now brown and slightly sticky (steady there!) I suspect the added strip is not original?
    Screen Shot 2018-12-09 at 14.10.39
    The second shows the screw fixing and a triangular plate under the sliding roof. Mine has the screw but not the plate, or is this hidden behind the head lining? I was expecting, once the screw was loosened, that the tin lid would be removable, leaving the lining in place or have I completely misunderstood? Perhaps the triangular plate clips over the side runner and once the screw is removed the tin roof and lining will lift off?
    Screen Shot 2018-12-09 at 14.10.29
