Reply To: Brake (and fuel line routing)
Traction Owner’s Club › Forums › Technical › Brakes › Brake (and fuel line routing) › Reply To: Brake (and fuel line routing)
#24238
Richard Larter
    Hi Norman
    My Light 15 is largely original and the brake pipe is routed through the floor stiffener with a rubber bung at each end and to further disguise any corrosion the pipes are wrapped in a tight wire spring! Not sure how they have survived nearly 70 years. Kunifer is more corrosion resistant but copper is easier to form around tight bends.
    Cheers Richard
