Reply To: Ignition Timing
#24525
Roger Grix
    Hi again David,
    I have just read a bit more on the 123 site and see that the traction distributor is pre-programmed with the Perfo and 11D curves and is switchable. The programmable unit is a different model and lets you design your own curve.
    Roger
