Reply To: LARGE CRADLE SPACERS
Traction Owner’s Club › Forums › Technical › Suspension & steering › LARGE CRADLE SPACERS › Reply To: LARGE CRADLE SPACERS
#24574
    My car has similar ‘adjustment pieces’ fitted on the nearside. Basically you measure the distance between the axle centres with the cradle fitted which should be the same both sides, if not it’s adjusted with spacers on the front cradle as Bernie describes.
