Reply To: Crankshaft oil seal kit
Traction Owner’s Club › Forums › Technical › Engine › Crankshaft oil seal kit › Reply To: Crankshaft oil seal kit
#24620
    Philip,
    Yes I have fitted one with reasonable success.
    Ideally, from a sealing point of view, the packing should not be cut and the single joint should be located at the top – i.e. in the centre of the top shell/cap.  I found this was best achieved by fitting the lower cap first then offering the top cap to the assembly and trimming the ends of the seal by trial and (hopefully no) error to achieve a tight joint.  Assembly is clearly not a simple operation and, I think, best done with the engine out for maximum accessibility.
    Additional lubrication should not be necessary but a very light coating of grease to the back of the seal may help it bed into the caps because it is important that the sealing element is correctly seated and firmly retained from the start to ensure the on-going integrity of the seal once it has been run for a while.
    B…………..
