Reply To: Slough windscreen wiper wheelboxes
Traction Owner’s Club › Forums › Technical › Other › Slough windscreen wiper wheelboxes › Reply To: Slough windscreen wiper wheelboxes
#24653
Roger Grix
    Hi Richard,
    Thanks for the feedback.
    My problem is not the motor.  I rebuilt that and had a great time re-fitting the 2 sets of 15 loose needle rollers.
    The wheelboxes on the Citroens have limited application.
    There are a lot of similar ones with different length shafts, knobs etc. and these appear to use the same main front section of the casting.
    I have been thinking that the problem is wear on the casting but, as I have been writing this and looking at a dismantled wheelbox, I am now wondering whether the wear on the casting may be a symptom and not the cause. I am wondering whether the problem is insufficient support of the cable inner where it passes under the wheel and relies on the clamping of the outer for support. Quite possibly, the inner is not meant to contact the casing at all
    Unfortunately, I am going to have to dismantle my system to find out.
    Roger
