Reply To: Ignition Timing
#24699
Norman Anderson
    Sorry for being such a moron, but I’m setting this up from the start….
    Where is the no. 1 cyclinder and what is the firing order? Also, which was does the rotor arm move when running (as viewed from above) the 123 manual says you need to know this!
    Guess the easiest way to find out when the no. 1 is on the compression stroke is to remove the rocker cover?
