Reply To: Radiator and horn mounting
Traction Owner’s Club › Forums › Technical › Engine › Radiator and horn mounting › Reply To: Radiator and horn mounting
#24718
    Norman,
    Rad fixing – there should be two captured M10 screws attached to the base of the rad.  These fit into holes in the cross member with a rubber washer (329600) and a cup (329610) on each screw , between the rad and the cross member.
    The assembly is then secured with a large flat washer, spring washer and M10 nut on each screw, below the cross member.
    The horn bracket attaches to two elongated cover studs in the top of the gearbox with spacers (703203) between the gearbox lid and the bracket.
    In general the spare parts catalogue is a far better reference source for seeing what goes where.  If you don’t have your own copy, it can be downloaded in pdf format from the Technical Library in the Members Only section of the website.
    B………….
