Reply To: WATER PUMP SEAL
Traction Owner’s Club Forums Technical Other WATER PUMP SEAL Reply To: WATER PUMP SEAL
#24723
David Selfridge
    Hi Bernie
    Thanks for your help and valuable information once again, much appreciated. The water pump is indeed the earlier type, I thought I had the complete original on-board toolkit, but the spanner for this job is definitely missing. It should be possible to make something up to do the job, any suggestions or pictures of the spanner.  I will post after tightening the seal to let you know the outcome
    Davy
