Reply To: Drain Tube
Traction Owner’s Club › Forums › Technical › Engine › Drain Tube › Reply To: Drain Tube
#24727
    BTW the OD of the pipe is just under 4mm if you want to make one yourself. If the manifold hole is is damaged by the bolt maybe look for a 4mm to 1/8th bsp fitting like this to repair the hole https://tinyurl.com/y4qgqkun
