Reply To: WATER PUMP SEAL
Traction Owner’s Club › Forums › Technical › Other › WATER PUMP SEAL › Reply To: WATER PUMP SEAL
#24740
David Selfridge
    Dave, all those pictures are more confusing, there are no dims showing thickness or even openings. The spanner my brother gave me would probably work if it was possible to get the spanner deeper, however the brass nut is almost touching the bottom of the main body of the Water Pump. This means the spanner has to be very accurate in dimension to pick up the slots in the nut before reaching the pump body on the opposite side.
    Thanks for your research.
    Davy
