Reply To: WATER PUMP SEAL
Traction Owner’s Club › Forums › Technical › Other › WATER PUMP SEAL › Reply To: WATER PUMP SEAL
#24750
    If you don’t have the spanner, you can use a centre punch or a dull chisel and a hammer- gently tap the centre punch in the slots to tighten the nut- do it with the engine running until the leak stops. That’s what I did on my 49 Legere.
