Reply To: Jambonneau sealing
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Jambonneau sealing › Reply To: Jambonneau sealing
#24754
    Richard,
    The original rubber was held in place by a spring clip and not attached to the body work with screws (= more points for rust to start).
    These parts (seal and retaining clip) are available from CTA :
    https://www.ctaservice.nl/product/14238/stuurstang-rubber-carrosserie
    https://www.ctaservice.nl/product/21426/ststang-rub-klem-v-232298
    Club Spares may also have them but I have not asked.
    Unfortunaely, fitting will require the coulmn to be removed again – but I would suggest that is probably better than splitting the seal which will risk creating a possible path for water ingress.
    B……………
