Reply To: Drive shaft play
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Drive shaft play › Reply To: Drive shaft play
#24971
John Dawes
    Hi Bernie, thanks for the advice. I would be happy to replace the whole shaft, but so far as I can tell, there are only CV joint ones available. I’ve not been able to find a source of recon/used replacement driveshafts. I could go to CV jointed ones (which I may have to) while I work out how to recondition the existing shafts. I guess these are a straight swap?
    Thanks, John
