Reply To: BRASS FILINGS INSIDE DISTRIBUTOR
Traction Owner’s Club Forums Technical Electrics BRASS FILINGS INSIDE DISTRIBUTOR Reply To: BRASS FILINGS INSIDE DISTRIBUTOR
#24990
    Check the strainer in the fuel feed at the carb, it may be low on fuel at speed under load. Even with a new filter before the pump I had sludge in mine…
    Coil OK, not getting overheated?
    • This reply was modified 7 years, 3 months ago by David Faulkner.
