Reply To: New transfer for '53 Slough Instrument cluster
Traction Owner’s Club › Forums › Technical › Bodywork & interior › New transfer for '53 Slough Instrument cluster › Reply To: New transfer for '53 Slough Instrument cluster
#25242
Roger Grix
    Hi Norman
    A word of warning. The transfers that I got were incorrect. The notch for lining up with the notch in the perspex so that the dial sits correctly in the case was incorrect. Not a problem as long as you know before you stick on the transfer. I had to cut a new notch in the perspex so that the dial was in the correct position.
    Before you start, sit the new transfer on your old dial and see if the notch is in the correct position. If not, mark the correct position and use your mark when fitting the transfer, ignoring the other one.
    This problem may have been sorted out but worth a check before you start.
    Regards,
    Roger
