Reply To: Fan Belt Pulley
Traction Owner’s Club › Forums › Technical › Gearbox & drive shafts › Fan Belt Pulley › Reply To: Fan Belt Pulley
#25384
    The shaft is driven off the camshaft. Assuming the engine runs the camshaft is turning. The shaft is connected to the camshaft through an Oldham coupling of Perfo engines and a splined coupling on 11D engines.
    I would imagine the change was made to avoid this happening – so is yours a Perfo engine?
    This link goes to Jose Franssen’s page which shows how this goes together:
    https://www.citroen-traction-avant.com/en/shop/article/S005/Cam_shaft
    Either the coupling itself has broken or the dog has snapped off one of the shafts – hopefully not the camshaft.
