Reply To: Striker rod ball joints
Traction Owner’s Club Forums Technical Gearbox & drive shafts Striker rod ball joints Reply To: Striker rod ball joints
#25550
    Noeman,
    There are lots of ball joints available but I think the biggest problem you will face is likelty to be the taper.  I shall check my “stock ” to see if I have any useable 2nd-hand bits.
    In the meantime, you might like to see if these people can help (I have used them for other items such as side mirrors on stalks) ….
    https://www.carbuilder.com/uk/throttle-linkage-parts#/pageSize=20&viewMode=grid&orderBy=0
    If not, more generally …
    https://www.google.com/search?sxsrf=ACYBGNQEso9qdqa-_541FAaeeXp3qslw0g:1568451488146&q=throttle+linkage+ball+joint&tbm=isch&source=univ&sxsrf=ACYBGNQEso9qdqa-_541FAaeeXp3qslw0g:1568451488146&sa=X&ved=2ahUKEwiNpbGO-c_kAhWtRxUIHcp4D2sQsAR6BAgFEAE&biw=1024&bih=715
    B…………
