Reply To: SUMP DRAIN NUT REMOVAL/REFIT
Traction Owner’s Club › Forums › Technical › Engine › SUMP DRAIN NUT REMOVAL/REFIT › Reply To: SUMP DRAIN NUT REMOVAL/REFIT
#25722
    22mm Davy is what I use on mine though I have new ‘magnetic’ drain plugs (from TOC spares) fitted to both the engine sump and gearbox. IIRC the original plugs had been abused over the years and weren’t such a good fit for the spanner.
    As for tightening, I always use a new copper washer and tighten until it ‘stops’  🙂
    • This reply was modified 6 years, 12 months ago by David Faulkner.
