Reply To: SUMP DRAIN NUT REMOVAL/REFIT
Traction Owner’s Club › Forums › Technical › Engine › SUMP DRAIN NUT REMOVAL/REFIT › Reply To: SUMP DRAIN NUT REMOVAL/REFIT
#25725
David Selfridge
    Hi David
    Thanks for you help, perhaps I should remove the drain plug, (before the funeral of my old Monkey Adjustable) then order a new Drain Nut from TOC spares. The engine oil Drain on my Traction looks very new and has a hard plastic seal ring, but measuring around 40mm Nut size.
    Davy
