Reply To: Slough wiper system overhaul
Traction Owner’s Club Forums Technical Other Slough wiper system overhaul Reply To: Slough wiper system overhaul
#25771
David Selfridge
    Hi Norman
    I had this problem with a French car which I had for resale. I could not source the rubber grommets anywhere, after a couple of sleepless nights and a few trips to motorcycle parts shops searching, I was about to give up, then finally  after rumbling around in my garage I discovered the bulbous end of a tubeless valves, cut from their stems were the perfect size and fit.
    Your are very lucky your working on a Slough car, as the French Cars  Wiper Motor can only be worked at, by laying on your back & fiddling with the tips of your fingers. End result, writers cramp and sore back for days after.
    Hope this helps, Davy
