Reply To: Front torsion rod installation
Traction Owner’s Club › Forums › Technical › Suspension & steering › Front torsion rod installation › Reply To: Front torsion rod installation
#25837
Martin de Little
    This may all be a bit late but no, you do not have to force anything. Importantly the t/bars are handed and should go back as they came out. Typically there is one dob of paint on one and two dobs of paint on the other.
    In a perfect world you will have scales and you  make adjustments via the adjusters  where the t/bar is held underneath the fire wall to achieve equal weights on the scales. . In the absence of the appropriate scales, most people seem to measure the height of the wing  from the ground just above the vertical centre line of the wheels .
