Reply To: Column mounted Lighting switch wiring
Traction Owner’s Club › Forums › Technical › Electrics › Column mounted Lighting switch wiring › Reply To: Column mounted Lighting switch wiring
#25955
Christopher Smith
    Thanks ; the  mystery  of the  3G   wire ! I had thought it  was  extra power via  ignition switch but  the tail light alternative  makes a lot of  sense Thank you
