Reply To: jambonneau to hull fitment
Traction Owner’s Club › Forums › Technical › Bodywork & interior › jambonneau to hull fitment › Reply To: jambonneau to hull fitment
#26079
Roger Grix
    Hi Norman,
    I think that I have cracked it – you need to click on the box before dragging and dropping the file.
    As I tried to say – one picture … or maybe 2.
    The curved bracket also provides the front latch for the bonnet catch.
    The top screw is countersunk.
    The bottom hole on the grille bolts to the flitch.
    NB If your radiator is original UK, the captive bolts will be BSF.
    I hope this helps.
    Part numbers are:
    For the cranked one: 329607 for 7 and 11L, 329608 for 11.
    the curved one: 298305.
    I don’t know where to suggest that you look. If Chris hasn’t got, I’m sure John Gillard will have. Otherwise place a forum request in the parts wanted. If all else fails, they would be quite easy to make.
    IMG_20200210_160245
    IMG_20200210_160313
