Reply To: Fuel Gauge Ohm Rating
Traction Owner’s Club › Forums › Technical › Electrics › Fuel Gauge Ohm Rating › Reply To: Fuel Gauge Ohm Rating
#26218
189
    This is turning out to be more confusing than I expected. The resistance at the gauge between B and T terminals is 60 ohms and T and earth is 100 0hms as you specify and the new  sender unit does have a range from 0 – 84 ohms. However the gauge seems to need inputs of between 0 – 190 ohms to register from empty to full, because the new sender at maximum extension shows no more than a quarter full. So something is amiss.
