Reply To: Wet liner heights.
Traction Owner’s Club › Forums › Technical › Engine › Wet liner heights. › Reply To: Wet liner heights.
#26245
    Richard if you can’t find a used set then Fransens have some ‘new’ ones at 84 euro each https://www.citroen-traction-avant.com/en/shop/article/DS%20121-010/Connecting_rod_without_half_bearings_new_compatible_for_11_perfo
    CAS are 92.07 for the same con rods
    TOC Club Spares are listed at £62.83so you will have to ‘shop around’
    You need the crank ground 1st to see what shells your going to need and that will determine the overall cost.
    Good luck.
