Reply To: Crankshaft oil seal kit
Traction Owner’s Club › Forums › Technical › Engine › Crankshaft oil seal kit › Reply To: Crankshaft oil seal kit
#26310
    Philip,
    Sorry for late response – if it is not too late I would recommend the original scroll – especially if you can remove the flywheel for access.  This will allow you to ensure centralisation – very important – as well as allowing you to get at the fixings.
    I would also suggest fitting a new one if possible because they do usually get distorted once fitted.  (And, yes, I may even have one and will look if you are interested).
    B.…………….
