Reply To: Water Pump
Traction Owner’s Club › Forums › Technical › Engine › Water Pump › Reply To: Water Pump
#26341
    Ken,
    Not terribly clear in your picture.
    Exact seal designs can vary but, basically, the softer (more flexible) “rubber” end goes against the impeller and the hard flat polished – usually ceramic- face mates with the pump body.
    The complete seal rotates with the shaft.  The internal spring holds the revolving ceramic element tight against the machined face of the casting to form a seal at that point.
