Reply To: Triangular rubber blocks
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Triangular rubber blocks › Reply To: Triangular rubber blocks
#26380
    Norman,
    Door alignment is adjusted at the hinges.  The hinge itself can be moved vertically by loosening the 17mm nut behind the B-post trim.  B
    They should not require removal but, if you do, be careful not to drop the nut or washer or they could end up in the sill.
    This adjustment will centralise the hinge end of the door vertically in the opening you then use shims behind the
