Reply To: Fuel Gauge Wiring
Traction Owner’s Club › Forums › Technical › Electrics › Fuel Gauge Wiring › Reply To: Fuel Gauge Wiring
#26428
Alistair
    Chris,
    Check out the wiring diagram in the members area.
    Basically, one goes to the sender and the other to the regulator. (12v). Which wire is which is a matter of testing with a voltage applied. Ideally use the sender in the circuit as a potentiometer to see the deflection of the needle. A correct needle movement will indicate which wire is which as per the wiring diagram.
    Alistair
