Reply To: Door removal
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Door removal › Reply To: Door removal
#26541
Norman Anderson
    Agree with Larry and Philippe, they are very heavy. 17mm socket inside the pillar. Be careful not to drop the nuts and washers.
    if you have a good trolley jack or two, you can use them to support the bottom of the door(s), especially when it comes to refitting.
    Shaving part of the pin head helps as well, saves you removing paint from the pillar when you refit the pins.
