Reply To: Internal windscreen surround
Traction Owner’s Club Forums Technical Bodywork & interior Internal windscreen surround Reply To: Internal windscreen surround
#26628
Ron
    Thanks, yes it is the front screen surround and a big boot model.  In the centre of the upper section is what looks like a giant 6cm wide overcentre clip, presumably covering the joint.  The issue seems to be the driver side(LHD) upper portion which is loose.  Does the centre clip slide to one side or is it gently persuaded to unclip allowing me to peep behind the surround.  Any pitfalls to be aware of before making this move apart from being prepared with new clips?
    Thanks. Ron.
